Require Updated Survey123 when using Custom URL
319
01-03-2023 09:02 AM
SuddhaGraves1
New Contributor II
Hello,
I am using a custom url to launch a Survey123 Form from a list in Dashboard.  I created the Survey123 Form in Connect and I have "Require update to the latest version of this survey" checked.  However, when it opens the Survey123 Form from Dashboard, if the Survey123 Form is already installed on the device, it will not check to see if it is the latest version.  Is there a way to force the form to ensure it is always the latest version?
Thank you,
Suddha
Tags (1)
DougBrowning
MVP Esteemed Contributor
Did you try opening the form without coming from a URL?  It will probably work then.  Coming from a URL seems to skip this and updating of CSV files.  This has been posted if you do a search I cannot remember what the status is.
SuddhaGraves1
New Contributor II
Yes, when opened from the Survey123 App it does honor the "require update..." setting.  I have tried searching for this on the blog, but haven't come across this issue.  I'll keep searching to see if I see any work-around.  Thanks!!
DougBrowning
SuddhaGraves1
New Contributor II
Thanks so much!
