Since the latest update (Feb 2024) I am encountering a repeat time stamp issue.
My survey contains a repeat and the repeat items have individual dateTimes. When cycling through the entries or adding a new entry the dateTime is overwritten to the current time. Only happens after the minute changes.
This was not an issue until the most recent Survey123 update for iPads.
Have you tried once() or changing the calculation mode to manual?
Reported as a bug through technical support.
It appears changing the calculation mode to manual fixes the issue. Thanks @DougBrowning !
