Hi @JosephSchmunkSF,
This is not currently possible, there is no automated way to remove surveys from a device. As different users may share a device, there are cases where one user may no longer have access, but another may still have access, depending on who is signed in.
We would need to support per-user surveys, where a survey is downloaded and tracked for a signed in user, not one shared survey for all users. This would enable options to remove/delete the survey if the signed in user no longer has access to it.
Manually deleting the survey via the "Delete survey" menu option in top right corner on the survey info page, or by removing the survey folder from the 'My Surveys" older on the device, is the only current way to remove it.
Regards,
Phil.
