I am creating a Survey123 form in Connect where one of the questions asks for the reason why they are wanting to enroll in this tree planting scheme. The question is a Select_Multiple with 12 possible choices. I would like a free text box to appear when 11 out of these 12 possible answers are selected.
I have read the following similar questions asked on GeoNet but the only solution I can find that works is one I have used on a previous form but is not ideal in this scenario:
Select_Multiple Relevant in Survey123: Follow up questions for only answers selected - https://community.esri.com/t5/arcgis-survey123-questions/select-multiple-relevant-in-survey123-follo...
"Relevant" field syntax for multiple choice questions - https://community.esri.com/t5/arcgis-survey123-questions/quot-relevant-quot-field-syntax-for-multipl...
The art of hiding - https://community.esri.com/t5/arcgis-survey123-blog/the-art-of-hiding/ba-p/898454
How Do I Apply A Rule In The Relevant Column When Using Select_Multiple? - https://community.esri.com/t5/arcgis-survey123-questions/how-do-i-apply-a-rule-in-the-relevant-colum...
In the Relevant column I am using the selected() function to generate a text box if any of the 11 options are generated (screenshot attached). The issue arises when more than one of those particular answers are selected a text box is generated for each selection (understandably so). Ideally, I would like just one text box to show for the submitter to enter any relevant info irrespective of how many options are selected in the original question.
I have tried to create this in one expression listing the names of each option with 'and', 'or' etc with no luck. I have also tried using a contains() function to no avail too.
Any ideas are greatly welcomed. (Connect Version used is 3.9.120)
Thanks in advance,
Adam
