My question1 asks the user to identify the asset id. That works beautifully:
- autocomplete search("Manhole_IDs?<url>", ‘contains’, ‘MANHOLE_ID’)
Then I have a note that needs to display the work order number based on the asset id. It runs the following calculation:
- pulldata("@layer", "getValue", "attributes.WORKTASK_NUMBER",<url>, "MANHOLE_ID= ${question1}")
Is the where clause supposed to allow for inclusion of variables, i.e. values from previous questions?
If I hard-code the value in the where clause then the pulldata function returns the correct value. The documentation doesn't clarify if variables are supported, and Esri's Survey123 Connect samples don't show it either.
