Is it possible to link two surveys using the pull data function, while also controlling the appearance of questions in Survey 2 based on responses from Survey 1? Additionally, is it possible to filter the choices in a multiple-choice question in Survey 2 based on answers provided in Survey 1?
For all intent and purpose... yes.
This will probably do what you want: Survey123 Tricks of the Trade: pulldata("@layer")
Easy. You just use calculates and IF() statements to dynamically change content. What this looks like depends on the content.
