Hello,
I'm running into issues trying to pre-populate questions in a survey123 form using values from attribute fields with domains set up via a custom URL hyperlinked in that feature class's pop-up window:
arcgis-survey123://?itemID=221111ea4a944877ac56dab8e89e2d3a&field:siteID={OBJECTID}&field:System={System}&field:Subsystem={Subsystem}&field:Class={Class}&field:Subclass={Subclass}&field:Class_2={Class_2}&field:Subclass_2={Subclass_2}&field:Water_Regime={Water_Regime}
I'm able to successfully pre-populate questions in the survey for any field that doesn't have a coded-value domain and/or choice filters associated with them, which leads me to believe that either the coded-value domain or choice filter for the question is interfering with pre-populating using the custom URL above.
Anybody have advice on how to pre-populate the answers to questions using a value from a field in your feature class that has domains defined?
Cheers,
Zack
