Populate Workforce time field in Survey123 form
864
6
06-04-2018 05:27 AM
khalilramadeen
New Contributor III
Is there any way to calculate "Due time" field from Workforce into survey123 form as ID method?
The case that came up is the management needs to calculate the time between the time of receiving the assignment in workforce and the actual starting time of task.
Or at least we need to record the "Due time" field from Workforce into Survey123 form?
Please find attached for more clarification.
attached
JamesTedrick
Esri Esteemed Contributor
Hi Khalil,
This could be done through a slight editing of the Workforce project.  I would recommend looking at "Remotely Invoking ArcGIS Apps" from the Developer's Summit (slides, video).
JamesTedrick
Hi Khalil,
khalilramadeen
New Contributor III
Hi James,
Could you tell me how to reach to this script which mentioned in the slides and video?
JamesTedrick
Hi Khalil,
The word 'slides' and 'video' are hyperlinked appropriately.
khalilramadeen
New Contributor III
Hi James,
I tried to get it from the video and slides but I couldn't. Where can I find the json file for my project?
XanderBakker
Go to ArcGIS Online Assistant , where you will be able to access the json file of all the content of your portal.
khalilramadeen
New Contributor III
Thanks a lot Xander, I'm able to edit my project as needed
