We have a survey with a shift start and stop time. We need the user to enter specific times so we are using a Date type question and a separate Time type question to avoid the auto population of the time that occurs in a DateTime type question.
Is it possible to then combine the Date and Time results and combine those in a single field? I have tried a few configurations and calculations, but frequently receive a type mismatch error. I'd essentially like to replace the "default" time that gets applied to a date/dateTime field with the user input...
Here is how I envision the date and time question configuration:
type | name | bind::esri:fieldType |
date | ShiftStartDate | null |
time | ShiftStartTime | null |
Here is a calculation I have tried for reference of what I am trying to achieve:
type | name | calculation | bind::esri:fieldType |
text | ShiftStart | string(format-date($ShiftStartDate, "%m/%d/%Y")) + " " + string(format-date($ShiftStartTime, "%h:%M")) | esriFieldTypeString |
I am open to the ShiftStart field being date or string type in the service. Thank you!
