Is there a way to avoid entering the same survey more than once
294
08-08-2024 08:20 AM
SanchezNuñez
Good morning,
We have a Survey123 connect where the surveyor selects a value in a drop-down list and populates the rest of the fields from the survey and submits it.
Question: when a surveyor submits a survey, is there a way to show that the value was entered?
Let's says that the drop down list has 5 values:1.2,3,4,5  If the first surveyor  submits a record for value 1, is there way to show that value 1 was already entered, so the other surveyors process values 2 to 5?
Thanks
ClayDonaldsonSWCA
assuming that they have internet connection when they start the form, this can be accomplished with pulldata() function. See blog posts here:
Survey123 Tricks of the Trade: pulldata("@layer") - Esri Community
If you pull the values from previous surveys, you could even use the choice_filter column to filter out records that have already been submitted.
ClayDonaldsonSWCA
SanchezNuñez
Good morning @ClayDonaldsonSWCA
I was able to do if with the pulldata() function.
Thanks
