I publish a survey as:
- Geopoint
- Table 1 (repeat)
- Table 2 (repeat)
I then publish a second survey targeting the existing service with the intention of using a custom url to pass the point globalid and add records to the tables. I want to populate both Table 1 and Table 2 in the one survey.
- Table 1
- Table 2 (currently a repeat in the form, to recognize as second table)
This works well for one table, but having two tables gives issues like:
- two 'parentglobalid' fields needing to be present/populated from the custom url parameter
- Error 'Destination relationship not found for table'
- Error 'parent layer not found for table'
These seem reasonable with how repeats are used within survey design.
I believe I can bypass these issues by having table 2 be nested when first publishing and creating the hosted feature layer. But then I believe Table 2 won't have a direct relationship to the geopoint layer, but to Table 1? This is an issue later as we want a globalid-parentglobalid relationship between the Table 2 and the Layer for other surveys and mapping. I could add a custom guid field to store the layer globalid in Table 2 so it ends up like this:
- Layer (globalid)
- Table1 (globalid, parentglobalid)
- Table2 (globalid, parentglobalid [Table1], customguid [Layer]
Is it possible to submit against both tables but maintain the global/parentglobalid between the layer and table 2?
If not, is it possible to create an additional relationship class between the Table2 customguid and Layer globalid? Any comments on the +/- of doing so?
Otherwise does anyone have any good insight, suggestions or resources on working with relationships/guids with multiple repeats and targeting existing services?
