We are attempting to design a survey to be accessed via web form that allows review of survey records previously submitted from the field. To do this, I've created two surveys, one for field collection via the mobile app, and a second one that points to the same feature service using the submission URL parameter, with all fields set to read only with the exception of a few additional fields for entering review information.
This works fine, except that the repeats are still editable in the sense that they can be deleted or added using the buttons in the web form:
We can imperfectly get around accidental additions by making the fields in the repeat required and read-only (so it won't let them submit), but it seems that reviewers are still able to delete records from the repeat using the trash can button.
I've tried setting the [begin repeat] line to read-only, and have also tried setting the [bind::esri:parameters] column on the [begin repeat] line to allowUpdates=false and allowAdds=false, and neither seems to have any effect.
Is there any way to allow the repeats to be shown on the web form but not allow them to be added to or deleted?
