I'm attempting to open an existing Survey 123 record from Field Maps. So, when a polygon is tapped on within Field Maps, it opens up the existing record in Survey 123.
This is being done within Portal, not AGO. I've configured my URL like this: arcgis-survey123://?portalUrl=https://gisportal.XX-XX.com/portal&itemID=05af890f3d1a4dc6a82484a935933454&mode=edit&globalId={globa...}
This was formatted by following this post from Ismael: Survey123 Tricks of the Trade: Editing records in ... - Esri Community
The workflow that I need is for one user type to be able to fill out the initial record and then another user type opens up the existing record and signs off (using the Signature field type in Survey 123).
I have the survey completely set up and the URL that I constructed will open Survey 123 from Field Maps; however, the record is empty. I've tried many alternatives to this and I'm certain I'm pointing to the correct Global ID field. Is this a known shortcoming, or do I have my URL formatted incorrectly?
Paul
