Dynamic Choice List - Error with using our own feature service
528
09-22-2021 06:17 AM
RosemaryHatch
New Contributor III
Hi! Very excited about the search() feature, however is there a trick to recognizing which hosted layers can be used? I'm trying to pull in a list of addresses from one of our layers and don't get any results. I can replicate all of the examples listed in this blog, and have no problem using the example feature services, but I must be missing something.
In addition, I have no issues using the search() function with a linked csv.
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi @RosemaryHatch ,
When I attempt to run a sample query with your service, I am receiving an error.  You may need to check whether the service can support query operations.
- Is there a definition query applied to the service?
- Does the data source health check in server look good?
RosemaryHatch
New Contributor III
It does support query operations (prior to using the search function I have been using pulldata and custom js to grab the lat/long from a specific point - such as using this query.)
No definition query applied.
Data source health check (I had our administrator check) says it's good.
I can open a support ticket if needed, I was just hoping there was an easy answer. Thanks!
