I would like to use a dropdown menu instead of the select_one checkboxes because i have a list of over 200 items to choose from. With the check boxes, the user has to scroll through all of them to get to the next question int he form. Will this be added soon/ever?
Hi Gary,
thanks for your comment. Below is the design we have for the next update of Survey123 for ArcGIS. This is showing a select_multiple question with minimal appearance. We hope that this is what you are looking for. We will make this available very soon.
That’s perfect. Thanks,
--gary
The fix is available now. Update Connect to give it a try. Updates for the app in the Google Play and Apple app stores will be available in the next couple of hours.
https://community.esri.com/groups/survey123/blog/2015/09/24/world-vegetarian-day-october-1st-update
