Download image in Survey123 webapp blocked
231
04-18-2024 03:32 AM
LuisanaIG
Hello, I hope you are doing well 😉
I am having an issue when trying to download an image from the Survey123 web application.
I created a Survey123 Connect form and added a repeat where the user (field worker) could update images from their observations. From this survey, I created another one in Connect where the manager could check the field worker's observations and download the picture if they want to inspect them better, but when I click the download button, it seems like nothing happens.
My survey is embedded in a dashboard. I checked the inspector and it shows me this message:
I tried with other browsers and encountered the same issue.
Could someone help me address this?
Thanks in advance.
Note: Sorry about my english.
abureaux
MVP Regular Contributor
May be of help? Sounds like a WAB/EB issue.
ChristopherCounsell
This is a standard browser issue. Embedded websites aren't allowed downloads due to potential for malicious software.
You can embed the website with an allow-downloads parameter but it doesn't look like it is supported:
https://developers.arcgis.com/survey123/guide/embed-a-survey-using-an-iframe/
Would suggest embedding the survey data in a different way e.g. Survey123 widget
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/survey-widget.htm
Or non-survey; use the standard app widgets for map/data display and format the data using Arcade or the widget configuration UI.
LuisanaIG
Thank you so much for answer my question.
@abureaux Thank you for this information, I was really helpful! I don't know how to implement it, but I will check it with more time.
@ChristopherCounsellThank you for the links. They're helpful as well! It seems there isn't an easy way to enable downloads. It would be great if I could simply disable this button if I can't use it.
I will try all the suggestions.
Thank you!
