I have a Survey123 built in Connect that we've been using for 6 months. It's mostly used on mobile device, but some folks use the webversion to back enter records. Starting sometime with the last month, the Date and Time field are throwing an error:
"Operand type clash: bigint is incompatible with datetime2"
I've tried entering various dates and times to no avail.
I found one post that suggested changing the web setting to always use the latest version. I did change that but we were using the latest version already so that did nothing.
Update, I have a second date/time field (for the Excel non-UTC aware) that uses this calculation behind the scenes. It seems my issue is related to this since when I remove that field & calculation I get no errors.
${EventDateTime} + pulldata("@property", "utcoffset")*1000*60*60
I have changed my web to use the latest version, I checked that I have version 3.13 for Connect, and I have republished the survey.
I thought that the pull data and @ property is supported in web now?
Any ideas?
