Hi -
I am migrating some workflows from Collector to Field Maps and I am running into issues with my callback URL parameters.
The workflow:
- Click a polygon feature in Field Maps to view pop-up. Custom pop-up displays URL to launch Survey123 form and pass certain attributes to Survey123.
- Survey is completed by user. When user submits survey, Field Maps re-opens via callback to specified map.
This worked very well with Collector and was simple to configure. With Field Maps, I am getting some weird errors, even though I am following the documentation on both Survey123 and Field Maps help pages.
If I use a URL formatted like below, I get an error when attempting to open Survey123 from the URL. The error is in Survey123 and says "Error Unpacking":
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app /?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
This same error occurs when I modified the URL to be something like this:
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID}&callback=https://fieldmaps.arcgis.app://?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID}&callback=https://fieldmaps.arcgis.app//?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
If I use the callback URL without the referenceContext parameter included, the callback seems to work, but does display an on-screen error when returning to Field Maps; this happens with either of the formats below:
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app ://?itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app /?itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
Error:
I did check and the Survey123 data submits properly. I am returned to the proper map in Field Maps, but see this error each time.
Does anyone have advice on how to resolve this issue?
Thank you,
Erica
