Created form, using Survey 123 Web, with existing hosted feature
477
10-28-2022 07:09 AM
lmotta_ibama
New Contributor III
I created a form by Survey123 Connect, this is using in the field, but now, I would like create a survey in Web for validation of features from field (first Survey 123), this will be using in embed survey in Experience Builder.
For that, I need using a Survey123 Web from a exist feature layer.
I am tryiend using the Survey 123 Web, but, I don't find a direct manner for define the feature layer.
It is possible?
Tags (1)
IsmaelChivite
Esri Notable Contributor
Hi @lmotta_ibama  It does not matter what tool (Survey123 Connect or the web designer) you use to create a survey; your surveys can be opened in a web browser and through the Survey123 mobile and desktop apps.
Author your second survey in Survey123 Connect, and then open your survey in a web browser or add it to an Experience Builder app.
You cannot build a survey on top of an existing layer using the web designer. You must use Survey123 Connect for that.
lmotta_ibama
New Contributor III
Thanks @IsmaelChivite .
Yeap.
How a "lazy boy", I tried know if is possible using the Survey123 Web Designer.
I will create the other survey by Survey123 Connect, but, checking if the feature/functions is compatible in Web [1].
[1] https://doc.arcgis.com/en/survey123/desktop/create-surveys/quickreferencecreatesurveys.htm
