Create validation with multiple If statements in Sweet
343
05-03-2024 03:56 AM
RosieLaura
New Contributor II
Hi asking this on S123 board as there isn't a board set up for Sweet that I can find.
I am trying to set up validation for when I draw a line feature in Sweet, I can apply the following validation to the width field. The line feature is a field boundary and the width field is filled in by the surveyor in the form on sweet manually. The width must be a multiple of 50cm and between 100cm and 500cm. I have written two statements that work individually but not at the same time and need some help combining them.
// STATEMENT 1: validate width is in multiples of 0.5 - Check that numerical value is divisible by a number
var value = $feature["margin_width"];
var multipleOf = 50
if (value != null && value % multipleOf != 0 ) {
var msg = `Value ${value} is not multiple of ${multipleOf}`;
return msg;
return true;
// STATEMENT 2: validate width is between 1 and 5m
var Width = $feature["margin_width"];
if (Width < 0 || Width > 600) {
var msg = `Margin width ${Width} is not between 0 and 5m `;
return msg;
return true;
2 Solutions
RosieLaura
New Contributor II
HI Cody, Thanks for getting back so quickly!
It throws an error for an unexpected =
CodyPatterson
Hey @RosieLaura
I had mistakenly implemented the modulus function inside of the if statement, taking some Javascript and putting it in Arcade had broken it, my bad!
Here is an adjusted function:
var marginWidth = $feature["margin_width"];
var multipleOf = 0.5;
var isMultiple = (marginWidth % multipleOf == 0);
var isInRange = (marginWidth >= 1 && marginWidth <= 5);
if (isInRange && !isMultiple) {
    return "Margin width " + marginWidth + " is not a multiple of " + multipleOf + " and not between 1 and 5m.";
} else if (!isInRange) {
    return "Margin width " + marginWidth + " is not between 1 and 5m.";
} else if (!isMultiple) {
    return "Margin width " + marginWidth + " is not a multiple of " + multipleOf + ".";
return true;
Hopefully this will get you going!
Cody
CodyPatterson
Hey @RosieLaura
Could you give this a try and let me know if it helps out?
if ((marginWidth >= 1 && marginWidth <= 5) && (marginWidth % multipleOf !== 0)) {
    return `Margin width ${marginWidth} is not a multiple of ${multipleOf} and not between 1 and 5m.`;
} else if (marginWidth < 1 || marginWidth > 5) {
    return `Margin width ${marginWidth} is not between 1 and 5m.`;
} else if (marginWidth % multipleOf !== 0) {
    return `Margin width ${marginWidth} is not a multiple of ${multipleOf}.`;
return true;
 Hope that helps!
Cody
RosieLaura
New Contributor II
CodyPatterson
Hey @RosieLaura
return true;
Cody
RosieLaura
New Contributor II
That's brilliant thank you!
