Cannot Configure Survey123 Website
77
a month ago
PatrickMcKinney99
My organization has installed the Survey123 website on a virtual machine in Azure.  Our Azure team has configured the App Gateway so that (these are example domains) https://some.domain/survey123 resolves to port 5443 of the server, which is the port Survey123 uses.
The site resolves, but none of the assets are loading.  I am getting 404 errors with files trying to load at https://some.domain/assets/...  Notice that those assets are trying to load from the root domain, not /survey123/assets.
It appears that that assets folder is located on the C: drive of the machine where Survey123 is installed.  It also appears Survey123 is using Node.js
Does anybody know if there are changes I need to make to the Survey123 application files, or Azure App Gateway to get the site to load properly?
Thanks!
