Can a single Feature Class (used in a repeat) used in multiple Relationship Classes?
395
01-08-2024 06:40 AM
MarjorieDillinghamGOAA
New Contributor III
Hello everyone,
I am trying to use a Feature Class that is already in a Relationship Class to submit work orders to our maintenance data management system with a new survey.  Is it possible for one Feature Class to be a part of two Relationship Classes?
Trying not to break the integration or have to configure it again.  Would like to keep the current survey and Relationship in place at least until we can test the new survey and make sure data is passing between the systems successfully.
Thank you in advance for your assistance!
Marjorie
DougBrowning
MVP Esteemed Contributor
Yes I do this a lot.  You just have to maintain the keys yourself.  I have a big writeup on this here  https://community.esri.com/t5/arcgis-survey123-questions/mapping-with-survey123-within-a-polygon-or-...
Hope that helps
DougBrowning
Yes.
New Contributor III
Thanks Doug! I'll give it a try. I appreciate the quick responses.  Marjorie
