When Power Automate is connected to Survey 123 using this method for Enterprise the only surveys available are those owned by the account embedded in the workflow. I propose expanding this to any survey shared with the embedded account so they can run workflows for surveys other organization members own.
Our team needs to grant access to an external user solely for working with existing surveys, which is impossible to control if the embedded user also owns the survey. Expanding what the workflow can access without changing the user's scope would fix this issue.
