I would like to see the ability to use calculations (specifically sum) on geometry questions in the web interface. I have a geopoint in a repeat. I am using those repeated geopoints to generate a geoshape for the containing entry. This is useable in the Field App, but for my users, downloading and using the Field App can be one more thing that stops them from using the system.
Thanks for the feedback.
There is an enhancement request ENH-000141099 for this. If this is important to you, please consider raising a defect escalation via Esri Support Service to prioritize this work.
Zhifang
