[Updated June 16, 2020]
In this blog post I will describe how you can work with dates and time in Survey123 with XLSForm. I will also cover important concepts for you to understand how dates and time are modeled in ArcGIS.
To best follow instructions and concepts in this blog, I suggest you open the Dates & Time survey sample in Survey123 Connect. If you have a first look at this sample survey, it will much easier for you to follow content in the blog.
Next, spend some time going over the survey. I suggest you explore it first in Connect and you also bring it into your phone or a web browser to see what it feels like. The structure of the blog pretty much follows the sample survey.
The Basic Types and Appearances section of the survey sample explores the different ways in which a date or time question can be presented to the end user. Combinations of the question type and its corresponding appearances, will help you control the best user input style that fits the needs of your workflow.
The first question in this survey is of type date and it uses no appearance. A calendar control is shown for users to pick a date. Note that the question shows the current date by default. This is accomplished by setting the default column in the XLSForm to today().
The following 3 questions illustrate the use of appearances: Year, Month-Year and Week-Number.
As you exercise the calendar control, it may not be obvious, but you can actually tap and hold the arrows to quickly navigate back and forth in time.
The Date, DateTime and Time types of questions as well as their corresponding XLSForm appearances, help you control the user experience that you want to present to the end-user capturing the data, but it is also important to understand how that date will be stored in ArcGIS.
User input to the Date and DateTime questions will be persisted in ArcGIS in a field of type Date. Despite the name of this field type, ArcGIS does not store just dates in Date fields: ArcGIS date values always include time as well. Hence, there is a perfect match between DateTime questions in Survey123 and ArcGIS date fields, but when it comes to date questions in Survey123, you need to understand that actually the time will also be stored. But what time? Well, it depends:
It is a bit tricky to get your time to show in ArcGIS, so that deserves an explanation too. The thing is that by default, your web maps in ArcGIS will hide the time... even though it is actually always stored. The screenshot below shows how you can configure your popup to display time. If the show time check box is disabled, do not panic: Change the format to a numeric date format, and it will switch on.
Time values in Date and DateTime questions are always persisted as Coordinated Universal Time (UTC). This is important when you have people working in different time zones. ArcGIS clients will translate the stored UTC values into your local time zone. The only exception is ArcGIS Pro. ArcGIS Pro will show the time in UTC.
So far, I described how date and datetime questions behave. Lets talk next about Time questions, because they are special. For Time questions, Survey123 does not use the ArcGIS date type (which we know now that actually stores date and time). Survey123 time questions store values as a string. We did it this way, because otherwise you would get dates as well, and this could be confusing: Say you want to capture the time when a store opens.... you would not want the date in there... Now, because time is stored as a string, there is no information regarding the time zone in it. As such, you need to keep in mind that there will be no time zone coverstion. Later in the survey, we will explore how to capture times differently.
Date and DateTime questions store values as date objects including time. Time questions store values as text.
All graphical controls in the Survey123 apps will honor your locale regional settings. For example, if your browser or smartphone's locale is set to Spanish, then dates will be formatted the Spanish way (which is the correct one, by the way... just kidding). In the next screenshot I show what the calendar control will look like in a phone set with United States vs Spain regional settings. Note that when using the Spain regional settings, the day goes first, then the month and then the year, versus the US version where the month goes first then the day and then the year.
Additionally the format-date and format-date-time function allow you to convert date objects into strings.
In the following example, we use the wsdatetime question to capture the date and time at which a water sample was taken. The wstime question calculate will be hidden from the end-user and is used to extract the time entered and persist it as a string in military format. Note that the output of the wsdatetimequestion is stored in ArcGIS as a date object in UTC, versus the wstime which will be stored as a string using local time in your device.
type | name | label | calculation |
dateTime | wsdatetime | Sample Date/Time | |
calculate | wstime | Time | format-date(${wsdatetime},'%H:%M') |
The qualifiers in the format-date function are as follows:
Header 1 | Header 2 |
%Y | 4 digit year |
%y | 2 digit year |
%m | 0-padded month |
%n | numeric month |
%b | month name abbreviated |
%d | 0-padded day of month |
%e | day of month |
%H | 0-padded hour (24-hr time) |
%h | hour (24-hr time) |
%M | 0-padded minute |
%S | 0-padded second |
%3 | 0-padded millisecond ticks (000-999) |
%a | Three letter short text day |
Survey123 accepts three possible values in the XLSForm default column:
Technically, you could also apply default value using Unix epoch notation (in milliseconds), but this would only work in the Survey123 field app. For consistency across the field and web apps, it is best to use ISO 8601 notation.
This section of the sample survey will be useful to understand how you use formulas with dates and date-times, so you can validate user input, as well as pre-compute date values. The questions in the survey are self-explanatory, The best is that you have a look at the XLSFile to better understand how things are done.
Constraints: A common constraint you will want to enforce is one that ensures a date is in the past or the future. That is pretty straight-forward: .> now() will ensure the user input is in the future for example. If you want to reference another question in the survey, you can use something like this: ${birthdate}<today(). This will ensure that the birthday question has a value in the past.
In constraints you may be asked to ensure a value is always newer and older than a fixed date. The date function is very useful in these cases. For example, you can set a constraint such as . > date('2006-01-01') or ${manufacture_date} > date('2006-01-01').
If you need to work with time constraints, simply add the time component to the date() function using the ISO 8601 notation.
UNIX epoch | Decimal date | |
2 weeks into the future | now() + 14*24*60*60*1000 | date(decimal-date-time(now()) + 14) |
Calculate age from birthday | int((today() - ${birth_date}) div (1000*24*60*60* 365.25)) | int((decimal-date-time(today()) - decimal-date-time(${birth_date})) div 365.25) |
Minutes spent for lunch | int(${LunchEnd} - ${LunchStart}) div (1000*60) | int((decimal-date-time(${lunchends}) - decimal-date-time(${lunchstarts})) * 24*60) |
15 minutes from now | now() + 15*60*1000 | date-time(decimal-date-time(now()) + 0.0104166675) |
0.0104166675 is equal to (1 (day) / 24 (hours) / 60 (minutes) ) times 15 (minutes).
I recommend you work with decimal date format, because then your XLSForm expressions will work both in the field and web apps. The Survey123 web app ONLY supports decimal time.
If you plan to use date expressions in the web app, use the decimal-date-time function.
If you ever need to populate a Survey123 date or dateTime question using a UNIX epoch number, you can use an expression like this:
text | epoch | Epoch (milliseconds) | |
dateTime | mydate | The Date | date(decimal-date-time(int(${epoch}))) |
This section in the sample survey is very similar to the previous one, but shows some other techniques that may be handy. For example, note how a calculate question is used to get the Lunch time computed, and then that value is used in other expressions throughout the survey. A calculate is a type of question that will let you keep the result of a calculation without having to show it to the user in the survey.
You will remember that questions of type time are ultimately stored as strings in ArcGIS, however, as far as calculations go, you will treat them as numbers. That is actually pretty handy because otherwise, you would not be able to do much with them!
The last section in the sample survey shows other techniques to capture time.
If you are not familiar with input masks in Survey123 I recommend you have a look at the Esri custom columns help topic. Regular expressions are tricky to put together, but you can find loads of samples in the web.
So far, we have been looking at date and time questions that were visible in the survey. It is for this reason that we cared about the user experience (types of questions, defaults and appearances) as well as the validation of inputs (input masks, constraints). Now, in Survey123 there are a couple of handy question types that will capture time without the end user knowing. These questions are start and end. When added to your survey, like in the Sample you are looking at, they will not show in the survey to the end-user, but they will populate data in the Feature Service, that you can see from the survey123 web site or a web map.
Start and end will capture the exact date and time at which the survey was initially opened by the end user, and flagged as done. For you to see how this works, the best is that you load the survey in your phone, complete a couple of surveys and submit the data.
The start and end values are useful if you want to understand how much time people in the field take to complete surveys. To calculate the duration of the survey, you will need to download the data in FileGeodatabase or Shapefile format and calculate a new field with ArcGIS for Desktop. This ArcWatch article describes how you can calculate the duration between two date fields.
On top of start and end, which are optional, you will always get the Creation and Last Edit date and time for every row you add from Survey123 for ArcGIS. It is important to highlight here that the Creation and Last Edit columns are handled through ArcGIS Editor Tracking. The help has a good topic on Editor Tracking in case you are not familiar with it. Do not worry about enabling Editor Tracking in Survey123, because it is always enabled by default. This feature looks at the time when edits are made in the Feature Service not when the data is necessarily being captured or changed in the field. For example, if someone is working in the field while disconnected from the network, the start and end field will truly reflect the time when the user is working on the survey. The Creation and Edit Times will reflect the time when the data was actually submitted: May be immediately after data capture, or may be a couple days later while back in the office.
This was a long post, but I hope you find it useful.
