$$NCOLS + $$ROWMAP
8163
01-20-2012 05:44 PM
YongTian
How do we implement $$NCOLS + $$ROWMAP in map calculator? I would appreciate any advice. My email: yong.q.tian@gmail.com
curtvprice
Here's an implementation of   William Huber's neat idea of using the FlowAccumulation tool to generate xmap and  ymap. This uses the current processing environment, it will generate an error if the arcpy.env.extent or cellSize are not explicitly set.
(this code has a bug fixed - thanks Cameron!
from arcpy.sa import *
from arcpy import env as E
# Calculate $$NROWS and $$NCOLS from current environment
cellSize = float(E.cellSize)
nrows = int((E.extent.YMax - E.extent.YMin) / float(E.cellSize))
ncols = int((E.extent.XMax - E.extent.XMin)  / float(E.cellSize))
# Bill Huber's method for $$XMAP and $$YMAP: "1" flows "right", "64" (63+1) flows "up"
tmpg = CreateConstantRaster(1)
xmap = (FlowAccumulation(tmpg) + 0.5) * cellSize + E.extent.XMin
ymap = (FlowAccumulation(tmpg + 63) + 0.5) * cellSize + E.extent.YMin
# applying the same method for $$ROWMAP and $$COLMAP
colmap = Int(FlowAccumulation(tmpg))
rowmap = Int(FlowAccumulation(tmpg + 3))  # flowdir "4" is "down" (top row is 0)
ChrisSnyder
Honored Contributor
Unsuported in new v10.0 Map Algebra! Although you can get $$NCOLS through the describe property in Python or the GetRasterProperties toolbox tool.
See: https://c.na1.visual.force.com/apex/ideaView?id=087300000008DT2AAM#comments
You can still use the good ole' Map Algebra sytax in v10 though:
arcpy.gp.SingleOutputMapAlgebra_sa(blah, blah)
CameronScott
Thanks for this! I'm new to both rasters and Python so code like this is a HUGE help. However, I think there's a small bug.
Shouldn't the xmap setting be adding XMin instead of YMin at the end? I.e.,
Thanks again for the code, very useful.
curtvprice
XanderBakker
Esri Esteemed Contributor
It's always cool to see some of William Huber‌ ideas revive!
Thanx for sharing Curtis Price
curtvprice
No problem, I was just resurrecting some old posts of mine, getting them tagged and placed in GeoNet where they will be easier to find.
