Extract Multi Values to Points - 010005: Unable to allocate memory
204
4 weeks ago
AndrewWhite2
New Contributor II
I have a simple point layer of about 2,500 points representing homes. I wanted to analyze these against a Flood Depth Raster using the Extract Multi Values to Points tool, but it would crash instantly with "010005: Unable to allocate memory." As I have a fairly beefy computer, and I don't consider this data very large, I was pretty confused.
I ended up having to select ~800 points at a time to not produce the error, which then created about 4 new Value fields, which I then had to use a Max expression to combine those fields back into single field with the values for all points.
Seems like a pretty annoying process if that is how this tool handles datasets with over 800 features.
DanPatterson
MVP Esteemed Contributor
related
Solved: Extract Multi Values to Points Internal error in S... - Esri Community
are you using a point featureclass in a file geodatabase?
... sort of retired...
AndrewWhite2
New Contributor II
Yep! I uploaded an excel -> Display XY Data -> Export -> Copy Features just to make sure. The process failed on both the Exported and Copied Files, which were both in the geodatabase.
DanPatterson
Extract Multi Values to Points (Spatial Analyst)—ArcGIS Pro | Documentation
raises more questions about coordinate systems etc.
If you aren't using multiple rasters, then why not try
Extract Values to Points (Spatial Analyst)—ArcGIS Pro | Documentation
AndrewWhite2
New Contributor II
I actually did try that tool as well, but I had the same issue come up.
The study area is in the eastern half of South Carolina, and I am using the State Plane projected coordinate system for the State as well. Which I just say to confirm that the data is in an area well represented by the projection.
Cheers!
