I use ArcMap 10.5 and I try to add attributes from a polygon layer (governorates) to a point layer, I want to add the governorate ID to the attribute table of the point layer directly, and based on the spatial relationship (in the same table without use spatial join).
is there a tool to do this?
or can I make a code and use it on this field to extract data from the polygon layer?
The best example of what I want to do is to extract elevation values from DEM.
Regards.
