Capture the tap on the link within feature layer popup
642
10-07-2021 01:00 PM
RaymondLi
New Contributor III
I have the simple iOS app open the map from our enterprise portal by using ArcGIS Runtime SDK.
    // MARK: - AGSGeoViewTouchDelegate
    func geoView(_ geoView: AGSGeoView, didTapAtScreenPoint screenPoint: CGPoint, mapPoint: AGSPoint) {
        print("AGSGeoViewTouchDelegate Event")
        guard let featureLayer = self.featureLayer else { return }
        print("featureLayer is not null")
        // Identify the specified feature layer.
        mapView.identifyLayer(featureLayer, screenPoint: screenPoint, tolerance: 12, returnPopupsOnly: false) { [weak self] (result: AGSIdentifyLayerResult) in
            guard let self = self else { return }
            if let error = result.error {
                self.presentAlert(message: "Error Display Feature popup")
                print(error)
            } else if !result.popups.isEmpty {
                // Unselect the previous feature.
                featureLayer.clearSelection()
                // Select the new feature.
                let features = result.geoElements as? [AGSFeature]
                let selectedFeature = features?.first
                featureLayer.select(selectedFeature!)
                // Display a popup only if it exists.
                let popupsViewController = AGSPopupsViewController(popups: result.popups)
                // Display the popup as a formsheet -- specified for iPads.
                popupsViewController.modalPresentationStyle = .formSheet
                // Present the popup.
                popupsViewController.delegate = self
                self.present(popupsViewController, animated: true)
In the popup, there is some content is a URL. I want to capture the movement when user tap on the link. I will do some other action or redirect to some where else. How can I do it?
Nicholas-Furness
Have you tried the wantsToShowViewController(ofType:) delegate method? I haven't tried it but if the type is AGSPopupViewControllerTypeWeb then you could take a custom action. If it's not, then you should   still present the view controller using the parameters passed into the delegate method. Does that do what you need?
RaymondLi
New Contributor III
Nicholas,
Thank you. I am able to capture the event when user tap on the link. However, I also want to know the field that user tap on it also? Do you know anything about?
BTDS_GISAdmin
New Contributor III
I have similar problem. I know wantsToShowViewController(ofType:)  has parameter of wantsToShow svc:UIViewController. I want to get the _currentURL. I cannot get the property. I want to cast it to AGSWebViewController, but it complains the type is not in scope. Please help
