Hello everyone,
I am developing an app that uses QueryTask feature of Esri Android SDK. Evertyhing is perfect except one thing. QueryTask results return Attribute Values and I am displaying this values at Popup. Let me explain deeply. Results have district field. I use district_name with coded value. For example; When value 1 district name display Green, when value 2 district name display Blue. At the SDK side, I am able to show district name =1 or district name=2. I want to show real district name with CodedValueDomain.
I showed like left popup my attributes but I want to show like right popup. I dont know how to access codedValueDomains. I've read API documentation, samples etc.
Here is my code approach;
private class AsyncQueryTask extends AsyncTask<String, Void, FeatureResult> {
@Override | |
protected void onPreExecute() { | |
progress = new ProgressDialog(MainActivity.this); | |
progress = ProgressDialog.show(MainActivity.this, "", | |
"Please wait....query task is executing"); | |
* First member in string array is the query URL; second member is the | |
* where clause. | |
@Override | |
protected FeatureResult doInBackground(String... queryArray) { | |
if (queryArray == null || queryArray.length <= 1) | |
return null; | |
String url = "http://company.gov.tr/arcgis/rest/services/GIS/Parcel/MapServer/1" | |
QueryParameters qParameters = new QueryParameters(); | |
String whereClause = queryArray[1]; | |
SpatialReference sr = SpatialReference.create(102100); | |
qParameters.setGeometry(mMapView.getExtent()); | |
qParameters.setOutSpatialReference(sr); | |
qParameters.setReturnGeometry(true); | |
qParameters.setWhere(whereClause); | |
QueryTask qTask = new QueryTask(url); | |
try { | |
FeatureResult results = qTask.execute(qParameters); | |
return results; | |
} catch (Exception e) { | |
e.printStackTrace(); | |
return null; | |
@Override | |
protected void onPostExecute(FeatureResult results) { | |
String message = "No result comes back"; | |
if (results != null) { | |
int size = (int) results.featureCount(); | |
for (Object element : results) { | |
progress.incrementProgressBy(size / 100); | |
if (element instanceof Feature) { | |
Feature feature = (Feature) element; | |
// turn feature into graphic | |
Graphic graphic = new Graphic(feature.getGeometry(), | |
feature.getSymbol(), feature.getAttributes()); | |
// add graphic to layer | |
graphicsLayer.addGraphic(graphic); | |
// update message with results | |
message = String.valueOf(results.featureCount()) | |
+ " results have returned from query."; | |
progress.dismiss(); | |
Toast toast = Toast.makeText(MainActivity.this, message, | |
Toast.LENGTH_LONG); | |
toast.show(); | |
boolQuery = false; | |
Dan O'Neill
Will Crick
