Hello
I'm getting an error today in my pipeline that runs npm audit -prod
luxon 2.0.0 - 2.5.1
Severity: high
Luxon Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-3xq5-wjfh-ppjc
fix available via `npm audit fix --force`
Will install @ArcGIS/core@4.25.5, which is outside the stated dependency range
node_modules/luxon
@ArcGIS/core 4.21.0-next.20210721 - 4.25.0-next.20221108
Depends on vulnerable versions of luxon
node_modules/@arcgis/core
All version of ArcGis are using luxon versions that have this vulnerability. In git hub for luxon it says to update to newer versions
Is ArcGis going to release an update soon? if not i cannot release my app since i'm not allowed to deploy high severity vulnerabilities.
Is there a work around while you work on an upgrade?
Thank you
Fabian
