Access Pooling Properties - Dedicated/Shared - via REST API
1349
11
10-02-2023 10:35 PM
MatthewGeorge
Occasional Contributor II
Is it possible access the pooling properties for an Map/Feature Service via the REST API? I can see that it's possible to get/set the min/max instances but I can't see any properties that indicate if it is a shared or dedicated instance.
Trevor_Hart
Also the provider will be set to “DMaps” for shared pool services.
Trevor_Hart
Trevor_Hart
MatthewGeorge
Thanks Trevor, I'll take a look.
MatthewGeorge
Thanks Trevor but I believe that is just a setting for the ArcGIS Server itself where it will default to the shared instance pool for new services. I need to get the property for each individual service.
Trevor_Hart
Oh yes sorry that was the wrong link. Should be this one.
https://developers.arcgis.com/rest/enterprise-administration/server/editservice.htm
I’ve used this to bulk update the minimum instances for each service in the past.
MatthewGeorge
Yeah that's the only documentation I can find and there's no reference to whether the service is set to use shared or dedicated instances, only min/max instances.
Trevor_Hart
That’s what the provider setting indicates.
If it’s DMaps it’s shared pool. If it’s ArcObjects it’s dedicated.
Trevor_Hart
So this is a dedicated service
This is a shared pool service - notice the instances are set to zero
MatthewGeorge
What version of AGS is that from? I'm seeing min/max of 1/2 for shared and no provider property.
