Unable to update caption
233
04-25-2024 03:45 AM
pocalipse
New Contributor III
Hi
I'm trying to update the caption on a group control but nothing is happening in the UI from within my code in my C# module:
The caption value is updated and has the correct value when ever I run this code but the UI doesn't reflect this value - why?
I've tried using a label in my group on the ribbon as well but that doesn't update either.
What to do ?
pocalipse
New Contributor III
Hi @StephenRhea_NV5
Thanks for your reply. I don't like your answer but it is actually a great idea creating multiple groups.
EricPfirman
New Contributor III
Did you run Build or Rebuild?
pocalipse
New Contributor III
What do you mean ?
I'm trying to update the caption at runtime from my C# code in  a module.
StephenRhea_NV5
As far as I know, you can't update the caption of a ribbon item at runtime. However, you can create multiple group controls in your DAML file that have different captions and show/hide them at runtime via conditions.
pocalipse
New Contributor III
Hi @StephenRhea_NV5
