Hello Everyone,
I am trying to save/populate output of a raster file location in a textbox using a browse functionality button in Dockpane. However, I tried using the "show in file explorer" DAML ID reference "esri_file_openFileLocation" which is not working. Otherwise, if I tried using "esri_core_openProjectButton" it worked.
Can you please help me with the workflow or any suggestion?
Regards,
Abhijeet
public static ICommand CmdOpenFileLocation
get
return new RelayCommand(() =>
// IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("esri_file_openFileLocation");
IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("esri_core_openProjectButton");
var command = wrapper as ICommand;
if ((command != null) && command.CanExecute(null))
command.Execute(null);
There is no such id as "esri_file_openFileLocation". If you want to open ArcGIS Pro file "open" or "save" dialog, you can use OpenItemDialog or SaveItemDialog.
Thanks!
@ GKmieliauskas,
Thank you for sharing the information. I do appreciate your inputs. I have observe the list of DAML ids
https://github.com/Esri/arcgis-pro-sdk/wiki/DAML-ID-Reference-ADCore.daml .
My query is if I am able to use "esri_core_openProjectButton" then why not "esri_file_openFileLocation"
You use another id in your code sample: esri_file_openFileLocation. It is not esri_core_openFileLocation.
With esri_core_openFileLocation ICommand CanExecute with parameter null returns false. It means that you can't execute command. It could be that you need special type of object to pass as parameter for CanExecute and Execute.
Thank you for your response @GKmieliauskas . If you notice I have commented out the line No 7 which is esri_file_openFileLocation.
As I am in my learning phase of this technology, Can you please help me with the command for CanExecute and Execute in order to execute the esri_core_openFileLocation?
Any article or document is highly appreciated.
Regards,
Abhijeet
