You can use Pro commands to accomplish this task. To reuse existing Pro commands (like showing the catalog dockpane or view) you can use the following pattern (copied from a sample button command):
protected override void OnClick()
ExecuteProCommand("esri_core_showProjectView");
ExecuteProCommand("esri_core_showProjectDockPane");
/// <summary>
/// Generic implementation of ExecuteCommand to allow calls to
/// execute any Pro command / tool by using its Id
/// </summary>
/// <param name="proPluginId">Pro ID (command/tool) to run</param>
/// <returns></returns>
private static void ExecuteProCommand(string proPluginId)
var command = FrameworkApplication.GetPlugInWrapper(proPluginId) as ICommand;
if (command == null || !command.CanExecute(null)) return;
command.Execute(null);
Here is some documentation on this subject: https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Reusing-Pro-Commands
