I just updated from ArcPro 3.0.0 to 3.2.0 now the addin I created throws an error when trying to register a new table as a geodatabase.
ERROR 999999: Something unexpected caused the tool to fail.
Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug,
and refer to the error help for potential solutions or workarounds.
This DB instance's release does not support this operation. [This DB instance's release does not support this operation.]
Failed to execute (RegisterWithGeodatabase). Failed at Wednesday, October 9, 2024 08:42:23 (Elapsed Time: 6.37 seconds)
From my code if a table is not registered as a geodatabase, I open it as a standalone table
using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
using (Table worktable = geodatabase.OpenDataset<Table>(queryTableName))
var tableParams = new StandaloneTableCreationParams(worktable)
Name = queryTableName,
// creates the standalone table.
StandaloneTableFactory.Instance.CreateStandaloneTable(tableParams, MapView.Active.Map);
Then run this block of code to register it.
var uri = standaloneTable.URI;
List<object> arguments = new List<object>
// URI of the standalone table to be projected on the map
standaloneTable.URI,
// OBJECTID Value column
"UNIQ_ID",
// Takes the standalonetable URI and makes and registers with the geodatabase
var results = await Geoprocessing.ExecuteToolAsync($"RegisterWithGeodatabase_management", Geoprocessing.MakeValueArray(arguments.ToArray()));
Running ArcGis Pro 3.2.0
Oracle.ManagedDataAccess.Core 3.21.110
Referring to your other thread, was the Geoprocessing.ExecuteToolAsync working for the Pro SDK 3.0 to register the tables?
Yes I had been able to register new tables using Geoprocessing.ExecuteToolAsync the in version 3.0.
It could be due to incompatible field types. Have you looked into the tech support document for compatibility issues with Date or Oracle Number (38) datatype? Try setting the registry key as described in the document and run the add-in; if the issue persists, please log a bug through the support team.
My worktables are using Date and Oracle Number (38) columns, so this at least sounds like the problem. I had been using Number(38) due to ArcMap Originally requiring that data type so I am assuming now 'Long' is the preferred data type?
I was able to go though and add the registry key/value, this unfortunately did not resolve the issue.
I am currently running 3.2.0 though so is it possibly that I would need to update to 3.2.4 to try and resolve this?
