Customizing Pro UI with DAML
1023
7
08-08-2019 06:43 AM
AlexZlotin1
I am looking to simplify the Pro interface via a configuration addin. The items I am having trouble with are Quick Access Toolbar (I need to remove some of the buttons) and the Attribute Table (need to remove Add Field, Delete Field, Delete Selection and a few other buttons). Can this be achieved via DAML? Thanks.
UmaHarano
Hi Alex
You can customize the Quick Access Toolbar using a configuration by calling this override:
OnCreateQuickAccessToolbar
Panes such as Attribute Table pane are not extensible. You cannot remove buttons there.
Uma
AlexZlotin1
Thanks Uma, I appreciate the quick answer!
AlexZlotin1
Hi Uma,
Is it possible to remove the Customize QAT button programmatically in a configuration? I do not want the users to make any changes to the toolbar. Thanks.
UmaHarano
There is no way to remove the Customize QAT button at this point. We will look into adding this for the future.
Uma
AlexZlotin1
Thanks Uma. If the Customize QAT button cannot be removed, is it possible to remove the "More Commands" and "Customize the Ribbon" items from the QAT menu? We want to lock the UI and not let the users make any changes to it.
UmaHarano
Hi Alex,
I investigated this and I am afraid this is not possible to accomplish at this time.
Uma
FrankLee1
Hi Uma,
l have two questions about this. l'm using pro sdk 3.0 .
Firstly,  is it possible to remove the "More Commands" and "Customize the Ribbon" items from the QAT menu at this time?
Secondly, is it possible to modify daml file not using a configuration to change QAT buttons?
For instance, modifying quickAccessToolbar label in daml file to remove QAT buttons.
