View FC geoprocessing history in Pro UI?
409
03-08-2024 12:28 PM
Bud
Notable Contributor
ArcGIS Pro 2.9.12; Oracle 18c 10.7.1 EGDB:
Is there a way to view an enterprise geodatabase FC's geoprocessing history in the ArcGIS Pro UI?
Or is a FC's geoprocessing history only available in an exported XML file?
DrewFlater
@Bud you can change the Metadata Style to anything except the default Item Description in order to see the geoprocessing history that is stored in the dataset metadata.
https://pro.arcgis.com/en/pro-app/latest/help/metadata/view-and-edit-metadata.htm#ESRI_SECTION1_0FAB...
Robert_LeClair
Esri Notable Contributor
If you go to the Analysis tab and in the Geoprocessing group, there is the History command there.  Or are you looking for something more specific?
Bud
Notable Contributor
Thanks.
I'm looking for the complete geoprocessing history of a given FC, the equivalent to what I can see in the XML:
That XML geoprocessing history goes all the way back to when the FC was created in ArcMap 9.3.1 (?) in 2011.
Robert_LeClair
Is this what you're looking to do?  See image below.  Go to the Project tab ->Application->Geoprocessing and check the "Write geoprocessing operations to XML log file"
DrewFlater
