Summarize Within Summary Fields not working
2116
03-28-2023 09:00 AM
KatMcDonald-Miranda
I've been using the Summarize Within feature for a while to get the count of points and the process works fine. However, I am now adding the Summary Fields function to get the mean of a particular field.
The field is numeric and there are no null values (the filter has not prevented me from running Summarize Within previously, though this is the first time I'm trying to use the Summary Field). The tool runs, but fails and here are the details:
When I remove the Summary Field, the tool runs fine. I'm using ArcGIS Pro, 3.1.0 and it is up to date.
Corey_M
Hi @KatMcDonald-Miranda
From looking at the screenshots it would appear that the output feature class name is too long. This may result in a long file name, and thus, the error is returned.
To attempt to resolve the issue, you could try to specify a shorter name in the Output Feature Class parameter when running the tool. Esri recommends using a short name. Error: 100014: Summarize within failed (esri.com)
I hope this helps!
Thank you,
Corey
KatMcDonald-Miranda
Thank you, @Corey_M , but that did not work.
