sum multiple fields
378
05-03-2024 06:56 AM
MauroRoma
New Contributor II
hi to everyone,
in arcgis Pro 3.1, how can I sum many numeric fields of a table. I want to insert the sum, or other statistical operations, of 180 fields (horizontally) into a new field, is there a tool already set up that allows me to do this?
Thank you and greetings
M.
MauroRoma
New Contributor II
Ed_
by MVP Regular Contributor
The Summary Statistics tool will do the trick 🙂
Question | Analyze | Visualize
JoshuaBixby
MVP Esteemed Contributor
I believe the OP wants to sum over all columns for each row, which is the opposite of what Summary Statistics does.
MauroRoma
New Contributor II
Yes, exactly
my goal is exactly the opposite of Summary Statistics does. Apparently it is so simple but i can't find a appropriate tool
thanks
Ed_
Oh I see yeah you are right I thought OP wanted to get sum of each column.
Pivot table and then Summary Statistics might do it
MauroRoma
New Contributor II
Done!
I found the following amazing technical support:
https://support.esri.com/en-us/knowledge-base/how-to-calculate-the-sum-of-all-numeric-attribute-fiel...
see you!
thanks
MR
