Hello. I am currently using topology-enabled reshape edges tool to fix some drainage basins.
When I select the edges on my polygons, some of them are all nice and cool, the whole edge is a single edge, like the upper one on the image below. But for some reason, other edges appear completely shattered into pieces, like the lower one on the image, with all the pink dots. You can see there is no other polygon for there to be multiple intersection points.
I tried selecting multiple edges and drawing a single line, but the error occurs then. What could be causing this?
