Pro 3.2.2 Will Not Do a 1:M Join
336
6
05-02-2024 01:07 PM
AKRRMapGuy
I am currently trying to create a model that will run as a geoprocessing service on ArcGIS Server 11.2.
I cannot get ArcGIS Pro to do a 1:M join between a Feature Class and a table in a FGDB. It definitely should be a 1:M situation, but it insists on trying to do 1:1 and therefor records are lost. ArcMap does the 1:m join just fine with the same FGDB. I have also tried using them as model variables rather than directly referencing the Feature Classes. That had no effect on the issue. All the data is in the same FGDB.
The Join Features tool does the join correctly, but the tool is incompatible with ArcGIS Server: 00151: Tool <value> is unsupported on server—ArcGIS Pro | Documentation
Any ideas?
Bud
Notable Contributor
  1. What tool are you using to create the join? Add Join?
  2. My understanding is that all joins in ArcMap are one-to-first (1:1). I don't understand how it could be possible that ArcMap is doing a 1:M join.
  3. Does the join work as expected when done outside of a model in the attribute table?
AKRRMapGuy
1. Correct, however Join Features and Join Field provides an expected result.
2. ArcMap has been capable of 1:M joins for my entire career in GIS. That's where I learned how to do them.
3. No it does not. When it misbehaves it misbehaves everywhere.
Bud
Notable Contributor
Add Join (Data Management)
The second table uses a join table with no Object ID field; only a one-to-first join is possible. A one-to-first join is also only possible if each table is from a different workspace. A one-to-first join is not a case sensitive match.
Records from the join table can be matched to more than one record if the join table has an Object ID field; otherwise, a one-to-first join will be performed.
AKRRMapGuy
Both tables have Object IDs.
AKRRMapGuy
Pro 3.3 added the option to give the user the ability to choose. I updated during this whole process.
After working with tech support it turns out that my issue had nothing to do with the Join in the model. Upstream from the join in my model I have an 'export table' tool. We identified a bug with that tool that involves issues with changing field names in the configuration, when used in Model Builder. It was likely making the 'Add Join' tool go nuts.
