I am am running a simple model that uses a secured feature layer and exports its features to GeoJson.
I can run the model in ArcGIS Pro Modelbuilder and everything works as expected.
If I convert that model to run as a scheduled task, nothing happens. No errors either.
I have access to the secured feature layer via my AD login so I thought maybe I needed to run the task with my credentials but still no luck.
Do I need to add reference to my ArcGIS Pro project to the script knows how to find the layer?
Any help is appreciated.
Thank you,
Mele
@MeleKoneya I would recommend exporting the Model to a python script. Then, in the script, add the following line:
arcpy.SignInToPortal("https://webadaptorhost.domain.com/webadaptorname",
'username@DOMAIN', 'password')
If the script executes successfully, you can easily schedule this as well. Check out the document here.
