Hello Everyone,
I have the following scenario:
The company I work for has several warehouses. We offer a 4HR delivery service, however, we know that each region has a different infrastructure and therefore, it is not possible to cover the same distance within 4HR. I have managed to determine the possible distance to be covered for each warehouse. Some cover 80, others 100, and others 120 miles.
However, I need to make this logic work using the Location Allocation strategy (Problem type: Maximize Coverage and Minimize Facilities).
The idea is to check, based on the possible distance, how many warehouses I should use to serve a particular network of customers.
I managed to do this through the Closest Facility strategy, inputting the mileage limit in the "Cutoff_Miles" column within the attribute table, but this column does not exist for "Facilities" within the Location Allocation strategy.
Could you help with this point?
