Join fields can not be processed
812
01-29-2023 09:25 AM
SD4
Hello everyone,
I am quite new to Arcgis and facing a problem with joined data right now.
I did a join of a table to a point-type shapefile. In the attribute table everything looks fine. But I can not do any processing to the data that is joined data.
When I add a new field to the table and try to calculate something with the joined data, it sais, a column was specified that does not exist.
When I try to do geoprocessing with the joined data, it skips the joined data because of NULL or EMPTY distance field value.
When I export the attribute table, the joined fields are either empty or filled with 0.
Does anyone know what's the matter here?
DanPatterson
MVP Esteemed Contributor
use  Join Field (Data Management)—ArcGIS Pro | Documentation
to make a permanent join first
... sort of retired...
DanPatterson
SD4
Thank you for answering my newbie question. I really appreciate that.
