Using ArcGIS Pro 3.2.2, GIS Professional Standard, Administrator.
A client requested base flood elevation and ground elevation along FEMA floodplain cross sections. To better differentiate the values, we want to italicize one number and leave the other un-italicized, so "Base Flood Elevation, Ground Elevation". However, I can't seem to get the italics text formatting tag to work.
The current label class is set to Arcade and reads: "<ITA>" + $feature['NFHL_CrossSections.WSEL_REG'] + "</ITA>" + ", " + round($feature['NFHL_CrossSections_AddSpatialJoin.Z'], 1)
In testing similar tags there were no issues; bold and underline worked just fine. I also tried other common italics syntax with no luck (<em> or <i>). There are also no ampersands (&) in any of the features or data.
Am I missing something? Is this the wrong text tag? Will it not work if an "Add Spatial Join" is present?
Of course, we could make these labels as individual text boxes or duplicate the cross section feature, but both seem like less efficient options.
Appreciate any help!
