Is there a way to override a limitation of 10 000 vertices to max out at 1 000 000?
765
01-31-2023 06:59 AM
JacobZemo
The user is using the Build Footprints tool on their mosaics in ArcGIS Pro 3.03 with the computation method of Radiometry.
There is a limitation of 10 000 vertices when running this tool and they need more.
Is there a way to override this setting to max out at 1 000 000?
Thank you.
Kindest Regards,
Jacob Zemo
Robert_LeClair
Esri Esteemed Contributor
Jacob - to my knowledge no.  I looked at the parameters and the python code for it  on the Build Footprints GP tool.  I don't know if there's a way to do this via the ArcGIS Pro SDK but I doubt it.
