I was georeferencing some an image with the control point table open. ArcGIS Pro siezed up. I took a screenshot of the control point table so I could run and OCR on the image. I parsed the OCR interpretation into a text file hoping I could just import the ground control points. I tried following the format of a known valid exported Control Point files. Unfortunately when I try I get the error message: The input links file is invalid.
I can import other txt files that were created through the Export Control Points button. Here are the first few lines of the txt file. I have tried delimiting with spaces, tabs, and commas.
3.543748 19.309274 -12456400.952828 4855201.121859
4.725875 17.161628 -12456255.594780 4854926.868063
14.761690 20.905213 -12454970.391578 4855380.188203
1.638434 5.916982 -12456678.955308 4853459.891963
attached is the screenshot of the Control Point Table
