How can i convert LAZ file to DEM ?
4376
6
02-13-2023 06:16 AM
RehanChaudhary
i have a LAZ point cloud file and i want to generate a DEM from it in ArcgisPro to be used as an evaluation source for another layer. I am aware that LAZ cannot be open in ArcgisPRo. i tried using the Convert LAS tool with its default settings to convert LAZ to LAS file but it did not work for me . What is the right approach for converting such file to DEM?
Tags (4)
RehanChaudhary
so i figured out what was wrong. In my dataset the spatial reference was in Geographic coordinate  system so i had to convert it to projected coordinate system Here is my workflow .The above suggested workflow from @wizgis  helped me.
1) convert LAZ file to LAS by using the convert LAS tool
2) add the created LAS file to map and righ click on file in contents and then export LAS to create another LAS. in this tool's environment set the coordinate system.
3) finally use the LAS to RASter tool to generate the DEM
wizgis
Occasional Contributor II
@RehanChaudhary
You can probably use LAS to Raster tool and use Elevation as value field to generate DEM.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/las-dataset-to-raster.htm
Hope this helps.
RehanChaudhary
@wizgis but this requires LAS Dataset as input and that is what "Convert LAS" creates as output. i am not sure if my LAS dataset is correct as running the "Convert LAS" tool just creates a red rectangle on the map and then when i run the "LAS to Raster tool", it fails stating that cannot create output (Error 000210)
wizgis
Hi @RehanChaudhary
So I had a sample LAS file at my end and as you mentioned earlier nothing shows up when we add it in the map viewer as screen in this screenshot.
However, if you insert a local scene points show up and then if we run the to Las to Raster it works as shown in the following screenshots.
Can you try the same workflow at your end and see if it works.
Additionally, I was thinking if you had access to Drone2Map you could use that as well to generate DTM, DEM.
Hope this helps
RehanChaudhary
@wizgis it still fails stating the same error as i mentioned above
RehanChaudhary
Shauna-RaeBrown
What would I have to do differently to create a single DEM from 200+ LAZ files?  Thanks for anyone's help.
Tags (3)
