Hello,
I am using ArcGIS Pro v. 3.2 (desktop). I have a raster layer of Aspect. I reassigned values into 9 classes to reflect direction (no aspect, N, NE, E, SE, S, SW, W, NW). I then converted this layer into Integer format using the Int. tool.
I am trying to run the focal statistics tool to display the majority value within a circular neighborhood of 100 cells (1000 m). The tool will start to run, and then get stuck on 100%. No error messages, no warnings, etc. I've tried this a few times, and have waited over 2 hours on one occasion. Eventually, I just have to re-start the program.
Has anyone else run into this issue? Any troubleshooting advice?
Thank you,
Ali Mulla
maybe see if restarting your computer helps
maybe clearing ArcGIS Pro cache (under Project > Options > Display) helps
maybe save the raster in your geodatabase or if that doesn't work then save it outside the geodatabase and into your local drive (not OneDrive or Google Drive)
